Creating a Work Surface
Create a work surface from a constrained surface. The work surface is used to define surface curves in the U′V′ parameter space of this surface.
On the Windscreen tab, in the
Surface Preparation group, click the
Work Surface icon.
With the Reference face field
active, click on the constrained surface in the 3D view.
Figure 1. The Create Work Surface dialog.
- In the Offset field, specify the work surface offset from the constrained surface.
Click Create to create the work surface and to
close the dialog.
The defined work surface is displayed in the model tree.
Figure 2. Snippet of the model tree after creating the work surface.
