Importing a Report Template for Reuse
A report template can be imported from an XML file to reuse in the current POSTFEKO session.
On the Reporting tab, in the
Reports group, click the
Import / Export template icon. From the drop-down list select the
Import report template (*.xml) icon.
Figure 1. The Import report template dialog.
- In the File name field, browse for the XML file to import.
- Click OK to import the XML file and to close the dialog.
