Adding Additional Files to the Package
The .pre file is read to determine the required files to perform the simulation. Files that form part of the Feko project (but not required for the simulation) can be added manually.
- Click .
Select one of the following options:
- To replace the base file that was specified in the package configuration
file, select
Replace base
file. - To add additional files to the package configuration file, select
Add
file(s). - To remove a file from the package configuration file, click the Package files tab and select the file that you want to remove. Click .
Figure 1. QUEUEFEKO is showing the list of files included in the package.
file, select
