Activate / inactivate Aided mesh
Inactivate
To inactivate the aided mesh:
| Step | Action |
| 1 | Activate the Mesh / Aided mesh / Edit command |
| → | The aided mesh box is opened. |
| 2 | Select Inactivated in the field "State of aided mesh" |
| 3 | Click on Apply |
| → | The aided mesh is inactivated. If the by default values have been modified, these modifications are not saved in the memory in case of re-activation. |
Activate
To activate the aided mesh:
| Step | Action |
| 1 | Select the string Mesh / Aided mesh / Edit |
| 2 | Select Activated in the field "State of aided mesh" |
| → | The aided mesh is activated. |
