Modification/characterization of the electric circuit in the circuit editor context
Introduction
The procedures of modification and characterization are identical. First select is required and then edit the desired element.
Modifying/ characterizing a component of the circuit
To Modify or characterize a component of the circuit in the circuit editor*:
| Step | Action |
| 1 | Select the desired component* |
| 2 | Edit or Edit array the component |
| → | The dialogue box corresponding to the component is opened. |
| 3 |
Modify the information in the dialogue box:
| 4 |
Validate the information :
| → | The component has been characterized/modified. |
Note: * possibility of modifying at the same time several components of the same type by using
the Edit array command
