Delete Flux entities linked with ACIS entities
Introduction
It is possible to delete geometric entities Object, Volume, Face, Line, Point using the command Delete Force.
The deleting of entities behaves differently depending on the type of geometry :
- Geometry without ACIS link: built/imported outside the modeler context or with a version prior to Flux 11.2 version (included)
- Geometry with ACIS link: built/imported inside the modeler context
What entities deleted ?
What are entities deleted (or not)?
| "Delete" action |
Geometry without ACIS link (built outside modeler) |
Geometry with ACIS link (built inside modeler) |
| Force delete an Object | No object if no ACIS link |
| Force delete a Volume | Delete the volume and faces/lines/points entities linked with this volume (provided they are not used elsewhere) |
| Force delete a Face | Delete the face and volumes/lines/points entities linked with this face (provided they are not used elsewhere) |
| Force delete a Line | Delete the line and volumes/faces/points entities linked with this line (provided they are not used elsewhere) | |
| Force delete a Point | Delete the point and volumes/faces/lines entities linked with this point (provided they are not used elsewhere) |
Functionality « Remove Volume »
A geometric operation* allowing to remove a volume in an object composed by several volumes without delete this object, is available.
This functionality is accessible:
- By menu :
- By icon :
This functionality correspond to Force delete of the volume
