Header Block
The header block contains metadata for use by file readers to identify the type,
version and format of the file. This is a mandatory block. The keywords that are
used in this block are:
| Parameter | Type | Decription |
| FILE_TYPE | quoted_string | The only legal value is 'gbi' |
| FILE_VERSION | quoted_string | The only legal value is '1' |
| FILE_FORMAT | quoted_string | The only legal value is 'ASCII' |
The following is an example of a HEADER
block:
$-----------------------------------------------------------------HEADER
[HEADER]
FILE_TYPE = 'gbi'
FILE_VERSION = '1'
FILE_FORMAT = 'ASCII'
