Combine Solids
Use the Boolean: Combine tool to connect two or more solids together, retaining all of the material in both.
From the Geometry ribbon, click the tool.
- Optional:
On the guide bar, click
to edit the tolerance value.
Select solids in the following ways:
- Click Find on the guide bar to detect solids within the given tolerance.
- Manually select individual solids by left-clicking.
- Click and drag to draw a window. Only intersecting solids in the enclosed region are selected.
Review each intersecting solid by clicking
and
on the
guide bar.
Combine solids in the following ways:
- In the modeling window, hover over individual intersecting solid pairs and left-click to combine.
- On the guide bar, click Combine All to combine all of the intersecting solids.
Combine Solids Using the Context Menu
Quickly connect overlapping or intersecting solids without opening the Boolean: Combine tool.
- Navigate to the Geometry ribbon.
- While in idle mode, select the solids to combine.
Right-click in the modeling window and select from the context menu.
This has the same effect as using the Boolean: Combine tool with the Keep common interface option active.
