Create Spheres
Use the Solids: Sphere tool to create spheres with solid or bounding surfaces.
From the Geometry ribbon, click the tool.
Create the sphere using one of the following methods:
Method Procedure Free Drawing - Left-click on geometry or in space to create the sphere's center point.
- Move your mouse to uniformly resize and draw the sphere.
- Left-click to create the sphere.
Fit To - Select Surfaces, Solids, or Components from the guide bar.
- Select the entity in the graphics window. A sphere will be created.
- Modify the location, if necessary, using the move tool (
) on the guide bar.
4 Nodes Select four nodes through which a sphere is drawn. -
Modify the size and location of the sphere in the following ways:
- Resize the sphere by editing the radius in the microdialog and pressing Enter.
- Click on the face of the sphere and drag the slider to adjust the size.
- Click
to translate
and rotate the sphere using the Move tool. - Click
to fit the
sphere around a selected object. - Click
to fill the shape.
Tip: While placing or editing the sphere, use snap points to snap to predefined points on your model, such as
surface boundary fixed points or mid points of surfaces.
