Push or Pull Surfaces
Create/modify solids by dragging selected surfaces.
From the Geometry ribbon, Drag/Spin tool group, click the Drag
tool.
- Left-click to select the surface(s) to drag.
- Optional:
Select one or both of the offset options in the microdialog.
- Click
to remove
degenerations. - Click
to retain shared
edges.
- Click
Drag surfaces in the following ways:
- Manipulate the slider in the modeling window.
- Enter a drag value in the microdialog.
