Define Surface Mesh Size
Use the Surface tool to define local mesh settings on selected surfaces.
Select the surfaces on which to apply the mesh
control in the following ways:
- While in the Mesh ribbon, select surfaces, then right-click and select from the context menu.
- From the Mesh ribbon, click the
Surface tool.
Select surfaces.
- In the dialog, define surface mesh options.
From the guide bar, execute the command in the following
ways:
- Click
to confirm your selection and remain in the
tool.This allows you to continue creating instances and helps you visualize and edit instances with the legend.
- Click
to confirm your selection and exit the
tool.
- Click
