VIEW
Specified view by user to allow for legacy support of a restart file.
VIEW(“name”) {parameters}
Qualifier
User-given name
name (string)
User-given name of the command. The instance of a given command is referenced using this parameter.
restart_file (string)
Path to restart file of the view (*.vct)
active_flag (boolean)
Read and process the command or ignore it
VIEW("Blade iso"){
     restart_file              = "usrViews/bladeIso.vct"
Excerpt from .vct file:
trans_restart_version: 10
zoom: 282.924255
angle_axis: 1.194084 0.210795 0.977075 -0.029840
translation: -0.000260 -0.000718 -0.001936
scale: 20.000000
outline: 0
perspective: 0
perspective_angle: 40.000000
perspective_z: 0.000000
axis_markers: 0
mouse_mode: 2
light_direction: 0.577350 0.577350 0.577350
rotation_center_on: 0
rotation_center: 0.000000 0.000000 0.000000
quick_transparency: 0
