Section Cutplane
Create a section cut output.
cut = vwt.SectionCut(normal)
- normal
- Plane normal specified as a triplet, for example (1,0,0).
Attributes
- length
- width
- height
- xMin
- xMax
- yMin
- yMax
- zMin
- zMax
- center
- normal
- Plane normal
- startType
- Set start type to Time or Iteration
- startTime
- Set start time to write output
- startIteration
- Set start iteration to write output
- samplingType
- Set sampling type to Target Frequency, Refinement Level, or Output Interval
- targetFrequency
- Set target Frequency to automatically compute output timestep size
- refinementLevel
- Set refinementLevel to automatically compute the sub-timestep size
- outputInterval
- Set output timestep size in iteration units
Methods
- properties()
- List of valid property names
- getProperty("PropertyName")
- Get output status of property
- setProperty("PropertyName", True)
- Set output status of property
Python Script Command
from hwx.inspire import vwt
from hwx.inspire.vwt.demo import openDemoFile
model = openDemoFile('fan_volume.stl')
parts = model.parts
sOut = vwt.SurfaceOutput(parts[0])
//to get/set h3d format
sOut.h3d
//to get/set ensight format
sOut.ensight
//to get/set mergeOutputFiles format
sOut.mergeOutputFiles
//to get/set mergeAndDeleteFilesformat
sOut.mergeAndDeleteFiles
