Command Line Options for Output Files
The output formats are set via the solver deck parameters <merge_output_files> and <file_format>. See the Simulation Parameters section.
To merge existing output and/or to convert to H3D, the following command lines options can be used separately or combined:
Merge
ultraFluidX allows you to merge output files manually by running the --merge option in the command line. Using >> ultraFluidX --merge <input file or path> will merge EnSight Gold or H3D files. The unmerged files will be kept unless the command specifically indicates to delete them: >> ultraFluidX --merge --delete-unmerged <input file or path>.
Convert
| Setup input deck for ultraFluidX | <file_format> = ensight | <file_format> = h3d |
| <merge_output_files> = false | Default option | Significantly reduces the number of files. This should be selected for GHN runs as a basis for further post-processing. |
| <merge_output_files> = true | Additional time required for merging | Producing these files during the ultraFluidX run may be challenging for large cases due to memory requirements. It is recommended to write unmerged H3D and merge them as a subsequent step. |
