2025
Explore additional post-processing options related to the input result files.
View new features for HyperLife 2025.
Discover HyperLife functionality with interactive tutorials.
Fatigue Analysis is intended for solutions to structures in a large number of loading cycles.
Set up your model for analysis.
Run the model and view results.
Explode the model and create derived load cases.
Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
A graphical manipulator allows you to modify specific items directly in the graphics area using interactive tools.
Use the Section Cut tool to cut planar or deformable sections through a model.
Explore the various result plotting tools for the imported result files.
Annotate model results using Notes and Measures.
The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperLife.
Create your own user defined coordinate systems or select result coordinate systems.
Explore verification problems for SN and EN with time series loading.
