Browse to Data Folder and Import Files
- Start HyperStudy.
Start a new study in the following ways:
- From the menu bar, click
- On the ribbon, click
- In the Add Study dialog, enter a study name, select a location for the study, and click OK.
Go to the Define Models step. Click Add
Model and add Existing Data model.
Figure 1. -
Define Solver Input File as beam.h3d and click
Import Variables.
Figure 2. Import dialog will appear. -
Browse to the Data folder in the study directory and click Search
Directory for Files.
Figure 3. This will enlist all h3d files in the Available Files section. -
Select all the available files and click Add All Files
to send them to the Chosen Files section. Click
OK to close the window.
Figure 4. Import step will generate one Input variable and two responses. These are typical used for internal purposes. However, they might be useful to perform reference checks and reports.
Input Variable: Existing Data Input Uri (list of location of each result file)
Responses: Existing Data Output Filepath and Existing Data Output Uri
- Go to the Test Models step and click Run Definition.
