HyperMesh Scripting Style Guide
There are Tcl/Tk programming conventions are recommended by Altair Engineering. They make scripts portable, readable and easy to update for others.
File Extensions
All Tcl/Tk scripts should be named with the .tcl file extension.
File Headers
# File : <file>.tcl
# Date : June 7, 2007
# Created by: John Smith
# Purpose : Detailed purpose of the script.
#################################################################Procedure and Namespace Headers
proc ::post::MyProc { args } {
# Purpose:
# Args:
# Returns:
# Notes:
}Any of the fields can be multiple lines if required for clarity. This might be the case with Args, where describing one argument in one line can make it more readable.
Notes can be used to document any special information, assumption, or warning considered relevant to the use of this function.
Any fields other than Purpose which may not required (in a small function, for example) can be deleted.
Variable names
- Name local variables using a mix of lowercase letters and underscores
- For example, local_variable
- Global variables should be prefixed with g_
- For example, g_root_val
- Namespaced variables should be prefixed with m_
- For example, m_x_loc
Procedure Names
- Capitalize the first letter of each word
- For example, SweepCurve
- Use upper case letters for abbreviations
- For example, MBPress for Mouse Button Press
Namespace Names
Namespace names should be comprised of the client name or a module name in lower case, followed by the user-defined namespace name.
- HyperView post client example
- ::post::MyNamespace
- HyperMesh example
- ::hm::MyNamespace
- General utility for creating a window example
- ::window::MyNamespace
- HyperMesh Example
- ::hm::MyNamespace::MyNamespace1
- Since Tcl does not have the ability to make variables or procedures read-only, you should limit creating and storing these in the global namespace ::
- While Tcl does not have the concept of private members, procedures and variables may be prefixed with p_ to imply that they are private.
Semicolons
set p_my_var 10; # Initialize my variableIndentations Using Spaces
if { conditional expression } {
# 4 spaces before first statement
# Code goes here
for { set i 0 } \
{ $i < $limit } \
{ incr i } {
# Code goes here
switch { $option } {
# 4 spaces before the first case statement
default {
# Code goes here
}Large Procedure Argument List
Procedures with a large number of arguments should be broken up to improve readability.
Long Command Syntax
set extremely_long_variable_name_for_pi [expr 2.0 * \
asin(1.0)];Procedure and Namespace Layout
When creating procedures or namespaces you should define any global and/or variable declarations at the top of the procedure or namespace, followed by the body.
variable m_attributes;
array set m_attributes {
color Black
style Solid
id 100
}variable m_color;
variable m_style;
variable m_id;
set m_color Black;
set m_style Solid;
set m_id 100;Example
# File : windowObj.tcl
# Purpose : Create a new window with options for moving it to a
# user specified location.
namespace eval ::window:: {
# Purpose: Used to create and control a window.
variable m_window .toplevelWindow;
variable m_geom;
# Initialize the default values
array set m_geom {
width 300
height 500
proc Create {} {
# Purpose: Create the window.
variable m_window;
catch {destroy $m_window};
toplevel $m_window -class Toplevel;
proc Show {} {
# Purpose: Display the window.
variable m_window;
if { ! [winfo exist $m_window] } {
tk_messageBox -message "No window exists.";
} else {
wm deiconify $m_window;
proc Reconfigure {} {
# Purpose: Resize the window.
variable m_geom;
variable m_window;
if {$m_window != ""} {
wm geometry $m_window $m_geom(width)x$m_geom(height);
focus $m_window;
