attribute sset
Sets selection set attributes.
attribute sset drawsize <integer> <all/name>
attribute sset drawstyle point|shaded|sphere|wire <all/name>
attribute sset visibility <true/false> <all/name>
Arguments
- drawsize
- Enter a value to change the thickness of the wire or the size of the point/sphere drawing for the active set.
- drawstyle
- Sets the drawing style for the active set.
- visibility
- Change the selection set's visibility.
Examples
Set the drawsize for all selection
sets:
attribute sset drawsize 5 allSet the drawsize for only a selection set
Set_50:
attribute sset drawsize 5 Set_50Draw style
examples:
attribute sset drawstyle point Set_16attribute sset drawstyle shaded Set_11attribute sset drawstyle sphere Set_15attribute sset drawstyle sphere allattribute sset drawstyle wire Set_50Set the selection set's visibility to
true:
attribute sset visibility true Set_1attribute sset visibility true "2D Set"
