delete animation
Deletes the model.
delete animation model <file>=<value1>
delete animation result <file>=<value>
Arguments
- model
- Delete the model.- file=<model filename>
- Select the file path or enter the name of the model to delete.
- id=<model id>
- Enter the model's ID.
- result
- Delete result files.- file=<result filename>
- Select the file path or enter the name of the result file to delete.
- id=<model ids>
- Enter the result files IDs in range syntax.
Examples
Delete the model
                truck.key:
            delete animation model file= "C:/model files/truck.key" id= 1
delete animation model id= 2Delete result files using the name and range
                syntax:
        delete animation result "d:/test/doe1.h3d"
delete animation result id=2-5
