hwd page
HyperWorks Desktop page commands.
hwd page add activewindow=<window_id> layout=<value> title=<title> type=<clienttype>
hwd page animateonce <active/all/<range>
hwd page copy append=<true/false> page=<page id>
hwd page current activewindow=<window_id> layout=<layout> title=<title>
hwd page delete <page id list> <titlelist>
hwd page draw
hwd page makecurrent <page id>
hwd page overlay page=<page id>
hwd page paste page=<page id>
Arguments
- add
- Add a new page. The following page settings can be defined:
- activewindow=<window_id>
- Set the active window on the new page.
- layout=<value>
- Define a page layout type. Enter a value between 0-19.
- title=<title>
- Enter the page title for the new page.
- type=<clienttype>
- Define the client type for the new page. Options include:
- HyperGraph 2D
- HyperGraph 3D
- HyperMesh
- HyperView
- MediaView
- MotionView
- TableView
- TextView
- animateonce
- Animate all animation windows on the given pages only once. The previous
timestep is restored.
- active
- Animate only animation windows on the active page once.
- all
- Animate only animation windows on all pages in the session once.
- range
- Animate only animation windows on pages within a given range once (for example, 1-4,8,10).
- copy
- Copy the page to the page internal stack.
- append=<true/false>
- Append the copied page to previously copied pages.
- page=<page id>
- Page ID of the copied page.
- current
- Manipulate the currently active page.
- Set the active window on the active page.
- layout=<layout>
- title=<title>
- The page title for the active page.
- delete
- Delete the page.
- <page id list>
- Enter the page ID or range of page numbers to delete.
- <titlelist>
- Delete a page by its title.
- draw
- Redraw the current page.
- makecurrent
- Define a page as active.
- overlay
- Overlay the copied page to a given page.Note: The page layout and client types in each window must match.
- page=<page id>
- Page ID of the overlayed page.
- paste
- Paste the copied page after a given page.
- page=<page id>
- Page ID of the page after which the copied pages will be inserted.
hwd page add activewindow=1hwd page copy append=truehwd page current activewindow=1hwd page delete 5hwd page delete 1-3,5hwd page makecurrent 3hwd page animateonce 1-4,8,10hwd page paste page=7hwd page overlay page=8
