report sessionreport
Synchronize report files.
report sessionreport export presention|document|html <filename> <name>=<value>
report sessionreport synchronize presentation|document|html <name>=<value>
Arguments
- export
- Export a session report. Select presentation, document, or HTML as the export file type.
- synchronize
- Synchronize a session report. Select presentation, document, or HTML as the file type.
- <filename>
- Enter a name for the exported or synchronized file.
- <name>=<value>
- Define the following properties:
- oneimageperwindow = <true/false>
- oneslideperwindow = <true/false>
- onepageperwindow = <true/false>
Export a session
report:
report sessionreport export presentation C:/Users/UserName/Documents/presentation1.pptx oneslideperwindow=falseSynchronize a session
report:
report sessionreport synchronize presentation C:/Users/UserName/Documents/Report.pptx
