result loadcase
Create and manage loadcases for derived loadcases.
result loadcase create <name>
result loadcase configuration export <config-file>
result loadcase configuration import <config-file>
result loadcase delete <name>
result loadcase <name> addbyfile <name>=<value>
result loadcase <name> addbyfileset <name>=<value>
result loadcase <name> options <name>=<value>
result loadcase <name> removebyfile <name>=<value>
result loadcase <name> removebyfileset <name>=<value>
result loadcase rename <name> <new_name>
Arguments
- create
- Create a loadcase.
- <name>
- The loadcase name.
- configuration
- export <cfg_file>
- Export a configuration file.
- import <cfg_file>
- Import a configuration file.
- delete
- Delete a loadcase.
- <name>
- Enter the name of the loadcase to delete.
- <name> addbyfile
- Add loadcases and simulations by file. <name> is the loadcase name.
- <name> addbyfileset
- Add loadcases and simulations by fileset. <name>
- fileset=<fileset_name>
- The fileset name.
- range=<range>
- For loadcases, the original IDs “lo:” or the index of the subcase “li:” can be used.
- <name> <options>
- Define options for a loadcase. <name> is the
loadcase name.
- constantscale=<value>
- Define the constant scale value.
- type=<steps/superposition/envelope>
- Define the loadcase type.
- typeofenvelope=<min/max/extreme/range>
- Define the envelope type.
- <name> <removebyfile>
- Remove loadcases and simulations by file. <name>
- file=<filepath>
- The file path.
- range=<range>
- <name> <removebyfileset>
- Remove loadcases and simulations by fileset.
- The fileset name.
- range=<range>
- rename
- <name> <new_name>
- Rename a loadcase.
result fileset create fs1
result fileset fs1 addbyfile file=C:/tmp/doe1.h3d,C:/tmp/doe2.h3d load=true
hwc result loadcase create "LC 1"
result loadcase "LC 1" addbyfileset fileset=fs2 range="lo:1-5 i:1-3,last3-last"result fileset create fs1
hwc result loadcase create "LC 2"
result loadcase "LC 1" addbyfile file= C:/tmp/doe1.h3d range="li:1,6 i:all"delete myLoadcaseexport config.cfg
import config.cfgrename myLoadcase testLoadcase
