save image
Save the current window or page as an image.
save image page <filename> <name>=<value>
save image window <filename> <name>=<value>
Arguments
- <destination>
- Destination can be either a <filename> or the string “clipboad” to copy the image to the clipboard. Use the file browser to enter a filename and select a directory to save the file to.
- <filename>
- Use the file browser to enter a filename and select a directory to save the file to.
- <name>=<value>
- If the following options are not displayed, the defaults values will be
used as described in config.
- <type>=<filetype>
- File type options include: JPEG, PNG, BMP, GIF, TIF.
- dimension
- Define as pixel or percent.
- width
- The image width.
- height
- The image height.
- quality
- For JPEG only. Enter a larger value for JPEG quality for larger files.
- page
- Save the current page as an image.
- window
- Save the current window as an image.
Save the active page as a PNG
file:
save image page C:\WorkingDirectory\truck.pngSave the active window as a PNG
file:
save image window C:\WorkingDirectory\truck1.pngComments
This command only works on the content of the active window.
