tracing display
Define the display options for traced nodes or lines.
tracing display line<name>=<value>
tracing display movewithtracking <true/false>
tracing display thickness <value>
Arguments
- line
- Select true or false to
show or hide the following attributes:
- originalline=<true/false>
- Displays the original line.
- surface=<true/false>
- Displays the constructed surface by the tracing lines.
- projectedline=<true/false>
- Displays the projected line.
- nodetrace=<true/false>
- Displays the node trace.
- movewithtracking
- Select true to move the trace with the entities relative to the tracking system.
- thickness
- Select a value between 1-10 to change the line thickness.
Define the display
options:
tracing display movewithtracking=trueDefine the line thickness:
tracing display thickness=4
