::Update
This command updates the state of a CheckBox widget from the value in the data member of the associated entity.
::model::mdlCheckBox::Update path
MotionView Tcl GUI
- path
- The full path to the CheckBox of interest. The path argument is the return value of the ::model::mdlCheckBox procedure used to create a CheckBox.
To update the value of a
CheckBox:
::model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity mrk Marker m_0 "\"Marker 0\"" "" ""
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 0 -column 0 -sticky nesw
set check_box [::model::mdlCheckBox .dlg.frm.check_box mrk "floating" -label "Floating" -enable true ]
grid $check_box -row 0 -column 0
::model::mdlCheckBox::Update $check_box
mrk ReleaseHandleErrors
None.
