::Update
This command updates the display value in an mdlFileName widget from the value in the data member.
::model::mdlFileName::Update path
MotionView Tcl GUI
- path
- The full path to the mdlFileName widget of interest. This argument is the return value of the ::model::mdlFileName procedure used to create an mdlFileName.
To update the value of an mdlFileName
widget:
::model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity entArray SolverArray sa_0 "\"Array 0\"" "IC"
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 1 -column 0 -sticky nesw
set fn [::model::mdlFileName .dlg.frm.fn entArray "ic_file.value" -editbar ""]
grid $fn -row 0 -column 0
::model::GetHandleFromFullVarname text_handle MODEL.sa_0.ic_file.value
text_handle SetRawExpression "c:/temp.txt"
model::mdlFileName::Update $fn
text_handle ReleaseHandle
entArray ReleaseHandleErrors
None.
