hwIPPTPublish SaveLinkedPptPresentation
Saves the linked PowerPoint file to the selected filename.
hwIPPTPublish_handle SaveLinkedPptPresentation filename
Tcl Query
- filename
- User-defined name that the file is saved to.
- File are saved with the user defined name at a specific location.
- The saved file is listed in the GetOpenPptList command.
To save the linked PowerPoint file with the defined
name:
PPTPublish SaveLinkedPPTPresentation "C:\Users\Smith\Desktop\presentation1.pptx" Error
Returns success (0) or an error code.
Keywords
Tcl
Query
