hwIPPTPublish SetDestination
Sets the destination/location to publish the session.
hwIPPTPublish_handle SetDestination type
Tcl Modify
- type
- The location where you want to publish a session. The session gets published to the
destined string type. If disk is given as string, then the appropriate
path should be specified in the SetPathOnDisk command.
- new
- Session is published to a new PowerPoint file.
- open
- Session is published to an opened PowerPoint file.
- disk
- Session is published to a specified file on disk.
This sets the PowerPoint destination to new. Replace new with
open or disk for other
options.
PPTPublish SetDestination new Error
Returns success (0) or an error code.
Keywords
Tcl
Query
