hwIPPTPublishOption SetGraphicsDistanceBottom
Sets the bottom offset of the graphics area.
hwIPPTPublishOption_handle SetGraphicsDistanceBottom p_image_bottom_offset
Tcl Modify
- p_image_bottom_offset
- The bottom offset of the graphics area.
To set the graphics distance from the bottom to 20 and change either the width or height,
whichever is not the master dimension (as UpdateResolution is true by
default).
Opt SetGraphicsDistanceBottom 20 To set the graphics distance from the bottom to 20, but not change the width or height as
the update resolution is false.
Opt SetGraphicsDistanceBottom 20 false Error
Returns success (0) or an error code.
Keywords
Tcl
Query
