hwIPPTPublishOption SetPictureResolution
Sets the picture resolution to the fixed/graphics or scaling factor option.
hwIPPTPublishOption_handle SetPictureResolution p_resolution_width p_resolution_height
Tcl Query
SetPictureResolution allows you to set the graphic width and height, which is reflected in the published PowerPoint file.
- p_resolution_width
- The resolution width of the graphics area.
- p_resolution_height
- The resolution height of the graphics area.
To set the desired picture resolution:
Opt SetPictureResolution ppt Error
Returns success (0) or an error code.
Keywords
Tcl
Query
