hwIWindow GetHTMLOutputType
Gets the window caption used when exporting to HTML.
hwIWindow_handle GetHTMLOutputType
Tcl Query
Returns the HTML output type for the window. This is a
string. It can be any of the following, depending on the client type of the window:
- JPEG
- AVI
- h3d
- Bitmap
- HTML
This parameter is used during HTML export. It indicates the type of the object created when the user clicks on this window in the HTML report. Not all options are supported by every client.
To determine the HTML output type of window 1 on page
1:
mySessionName GetProjectHandle myProject
myProject GetPageHandle myPage 1
myPage GetWindowHandle myWindow 1
myWindow GetHTMLOutputTypeError
If an error occurs, an empty string is returned.
