hwIWindow SetSyncOffset
Sets the offset of a given window.
hwIWindow_handle SetSyncOffset offset
Tcl Modify
- offset
- The new offset for the window.
To set the offset for a given
window:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWindowName 1
myWindowName SetSyncOffset 2.0Error
Success (0) or an error code (see below).
3 = HW_InvalidHandle if window handle is invalid.
