mdlIDataMember GetRefObjectHandle
Gets the handle of the object to which a reference data member is resolved to.
mdlIDataMember_handle GetRefObjectHandle ref_handle, resolve_ref
MotionView Tcl Query
This command gets the handle of the object to which either a reference data member is resolved to, or the reference data member itself.
- ref_handle
- The handle name used for the referenced entity.
- resolve_ref
- A boolean value which is by default true.
- True (Default)
- he handle of the object to which the reference data member is resolved to will be returned.
- False
- The handle of the reference data member itself will be returned.
To get a handle to an object to which a reference data member is resolved
to:
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle joint_handle j_cra_con_rev
joint_handle GetChildHandle myhandle b1 false
myhandle GetRefObjectHandle ref_handle true;
myhandle ReleaseHandle
joint_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandleError
Returns the handle of the object. If there is an error, an error code will be returned.
