mdlIModel AddAnalysis
Adds a new analysis from an existing data file.
mdlIModel_handle AddAnalysis new_handle varname label data_file_path
MotionView Tcl Modify
This command adds a new analysis using the 'varname', 'label', and 'data_file_path' arguments.
- new_handle
- The handle of the newly created analysis.
- varname
- The variable name for the analysis.
- label
- The label of the analysis.
- data_file_path
- The full file path that will be used to create the analysis.
To add a new analysis from an existing data file:
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName AddAnalysis ana_handle ana_0 "\"Analysis 0\"" C:/temp/data.mdl;
ana_handle ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandleErrors
Returns the handle of the newly created analysis if successful. If there is an error, an error code will be returned.
