poIComponent GetTranslation
Gets the translation vector in the global coordinate system.
Important: Please note that this command has been deprecated and therefore is not
recommended for use. See the poIPart Class for an
alternative command that can be used.
poIComponent_handle GetTranslation
HyperView Tcl Modify
This command returns the translation vector in the global coordinate system.
To get the translation vector of the component with an ID of
1:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetComponentHandle myComponentName 1
myComponentName GetTranslationError
Returns the translation vector if successful, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
