poIComponent SetTranslation
Translates a component by the vector given.
Important: Please note that this command has been deprecated and therefore is not
recommended for use. See the poIPart Class for an
alternative command that can be used.
poIComponent_handle SetTranslation translation_vector
HyperView Tcl Modify
This command translates a component by the vector given.
- translation_vector
- The translation vector.
To translate the component with ID 1, by 10 units in the X
direction:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetComponentHandle myComponentName 1myComponentName SetTranslation {10 0 0} Error
Returns 0 if successful, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
