poINote GetBackgroundColor
Gets the background/fill color of the note.
note_handle GetBackgroundColor
HyperView Tcl Query
This command retrieves the background color, or the fill color, of the note. The return value is a string which corresponds to the rgb color value.
To retrieve the background/fill color of the note whose id is
"2":
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetNoteHandle note_handle 2;
set fill_color [note_handle GetBackgroundColor]
hwi CloseStackError
Returns a valid rgb color if an invalid rgb color is set using the "SetBackgroundColor" API. Valid rgb colors are the 64 colors supported by HyperView.
