poINote SetBackgroundColor
Sets the background/fill color for the note.
note_handle SetBackgroundColor
HyperView Tcl Modify
This command sets the background color, or the fill color, for the note. This command will not have any effect if the transparency option is "on" for that note.
To set the background/fill color for the
note:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetNoteHandle note_handle 2;
note_handle SetBackgroundColor "100 200 100"
hwi CloseStackErrors
This command returns (0) if successful, or a "non-zero value" if an error occurred.
