poIQueryCtrl GetError
Gets the last occurred error description, or returns nothing.
poIQueryControl_handle GetError
HyperView Tcl Query
This command retrieves the last occurred error description, or returns nothing.
To get the last error
occurred:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetQueryCtrlHandle myQueryName
myQueryName GetErrorErrors
Returns the last occurred error, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
