poIQueryCtrl GetSelectionSetSize
Gets the size of the entities selection set that will be used to query the HyperView database.
poIQueryControl_handle GetSelectionSetSize
HyperView Tcl Query
This command retrieves the size of the entities selection set that will be used to query the HyperView database.
To get the size of current selection
set:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetQueryCtrlHandle myQueryName
myQueryName GetQuery GetSelectionSetSizeErrors
Returns the size of the entity selection set, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
