poIResultCtrl AppendSimulation
Adds a simulation reference to the current subcase.
poIResultCtrl_handle AppendSimulation subcase_id simulation_index
HyperView Tcl Modify
This command adds a simulation reference to the current
subcase.
Note: AppendSimulation will fail if the current subcase is
not a derived subcase.
A simulation can be added to a derived subcase only once.
- subcase_id
- The ID of the subcase which contains the source simulation.
- simulation_index
- The source simulation index.
To append a
simulation:
set dsub_id [rctrl AddSubcase "Derived_Subcase"]
rctrl SetCurrentSubcase $dsub_id
rctrl AppendSimulation 1 0
rctrl AppendSimulation 1 1Error
Returns the hwResult.
