poIResultCtrl GetDataComponentComplexFilter
Returns whether or not a data component can be used with various complex filters for the specified subcase and data type.
poIResultCtrl_handle GetDataComponentComplexFilter subcase_id datatype dcomp
HyperView Tcl Query
This command returns whether or not a data component can be used with various complex filters for the specified subcase and data type (true or false).
- subcase_id
- Set to a positive integer.
- datatype
- The data type label.
- dcomp
- The component of the data type.
To find out if a data component can be used with a complex filter (assuming a valid model
and result file is
loaded):
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle 1
model_handle GetResultCtrlHandle result_handle
result_handle GetDataComponentComplexFilter 1 Stress XX
hwi CloseStackErrors
None.
