Use Batch Mode
Learn more about using batch mode.
注: While using hooks during prediction from the command line, the hooks directory can be specified using the --hooks_dir <hooks_path> argument. The python hook and the _predict_inp.json or predict_inp.csv should be present in the hooks directory.
Batch command for training a physicsAI model:
<install location>/altair/hwdesktop/hw/eds/linux/edspy.sh -physicsai -train <model name.psmdl> -dataset <path to dataset> -spec <path to model spec>
Batch command for predicting on a new mesh or CAD model:
<install location>/altair/hwdesktop/hw/eds/linux/edspy.sh -physicsai -predict_write <output file name> -model <path to model> -input_file <path to input file>
注: On Windows, the paths above will be slightly different. For example:
<install>\hwdesktop\hw\eds\bin\win64\edspy.bat
