Analysis Manager
An Analysis is a collection of model configuration, analysis loadcase and analysis set-up selections that completely specifies the assembly definition for a particular loadcase simulation event.
Any Analysis is defined as a combination of model configuration, analysis loadcase and analysis set-up.
Model Configuration
Already defined model configurations are listed and can be selected for creating an analysis.
Analysis Loadcase
Analysis loadcase definition is a combination of loadcase and states for modules and connections. The loadcase definition and selection of states for modules and connections can be specific to a particular configuration or independent of it.
- Frequency Response
- This functionality generates the solver deck for user-defined loadcase templates supporting the automated generation of diagnostic requests.
- Normal modes
- Generates normal modes for the solver deck.
- Full deck TPL
- Generates the solver deck for user-defined loadcase templates.
- Process manager generated loadcase entities
- Generates the solver deck for the process manager generated loadcase templates.
- Solver deck
- If you select Frequency Response as the solution type, you are presented with the
following sub-tasks:
- Loadcase type selection
- Select a loadcase type for analysis.
- General
- Select pre-defined loadcases in terms of templates or solver decks.
- Standard
- Allows processing of advanced loadcases for:
- Road inputs
- Powertrain Loads
- Driveline Imbalance
- Wheel Imbalance
- Spindle Loads
- Select Analysis Frequencies
- Define the frequency range of analysis.
- Normal Modes Extraction
- Contains an option to specify normal mode extraction parameters for modal frequency analysis.
- Loading point selection
- You can define the loading points using the template or solver deck. Click Apply when you are done.
- Loading strength definition
- Loading strength information from the TPL files or the solver deck gets loaded
here. There is an option to review the loading strength and to edit/modify the
loading strength. To assign a new loading strength click the
icon. Loading
strength can be defined from external CSV, UNV or the solver deck.
You can select module states and connection states depending on the loadcase definition.
Analysis Setup
Analysis setup definition is a combination of module setup and diagnostic setup. The setup can be specific to a particular configuration or independent of it. This setup also allows you to specify the type of analysis: Regular, Multiple Sample Analysis (MSA) and Single Sample Analysis (SSA).
You can select the module representation type for a particular analysis setup.
- Select analysis type
- Define the analysis type, modal or direct.
- Response Selection
- Select response type and entities, and output file format.
- Diagnostic options selection
- Request diagnostic options, such as:
- Modal/panel participation
- Grid participation
- Auto TPA
- DSA (for gages, material properties, connection parameters, and modal parameters)
- ODS
- Element energy for concerned frequencies using PEAKOUT and OFREQ
- Global damping selection
- Define the global structural and fluid damping. There is an option to skip the structure damping and define only the fluid damping.
- Parameter selection
- Define additional parameters. You can enter the PARAM name and the default value will automatically be populated. These defined parameters get written out in the solver deck.
Tuning Sets
- Click
to activate the tuning sets.
Batch Runs (Interactive)
You can submit batch runs for a combination of defined model configuration, analysis loadcase, analysis setup and tuning sets.
- If the Create job option is selected, select a Job folder and click Create Job, which opens the Job Submission dialog, allowing you to select a number of solver related options.
- You can select the server, local or HWUL for solving the runs.
- Click Submit Job to create the analysis job and submit it to the target solver for analysis.
- If the Export deck option is selected, click Export to save a solver deck for manual submission to the targeted solver for analysis.
Analysis Definitions Import/Export with Template CSV Files
This option allows you to export and import analysis definitions in template .csv files. This will allow you to quickly create analysis definitions by importing the template .csv files, compare and modify analysis definition.
Analysis Definitions Review
This option allows you to compare different analysis.
Optimization
- After applying the Analysis, click
to add the optimization setup.
From the tabs, you can create Design Variables, Design Responses, Derived Responses, Constraints, and Objectives.
