2025
Access the Assemble, Analyze, NVH Tools, NVH Post, and Physics AI ribbons.
Set up the simulation model, materials, domains and boundaries.
View new features for HyperMesh NVH 2025.
Discover NVH functionality with interactive tutorials.
An Analysis is a collection of model configuration, analysis loadcase and analysis set-up selections that completely specifies the assembly definition for a particular loadcase simulation event.
Use the Check tool to reduce the amount of manual work involved in performing a normal modes run to check out multiple modules by batch processing.
Use the Reduce tool to reduce the amount of manual work involved in generating CMS superelements or CDS superelements for multiple modules by batch processing.
Use the Job Manager tool to interact with analysis jobs created through the NVH Director.
Use the Tuning Set tool to create standard tuning sets that can be used in the Analysis Manager for automatically setting up quick modification runs in NVH analysis.
Use the Response tool to create defined response points that will be automatically used in setting up output requests in NVH analysis.
Use the Frequency tool to create standard analysis frequency sets that will be automatically used in setting up analysis frequencies in NVH analysis.
Use the Control Volume tool to create defined control volumes that will be automatically used in setting up Transfer Path Analysis diagnostic output in NVH analysis.
Use the Panels tool to create panel sets by selecting nodes/elements and/or existing node/element sets in the model file in the prepare module mode. These panels are automatically used in setting up Panel Participation and ERP diagnostic output in NVH analysis.
Create, organize and manage the CAE parts.
Define radiation conditions and create emissivity models.
High frequency NVH is an implementation of Statistical Energy Analysis (SEA), and is used to predict and analyze the vibration and acoustic response of complex dynamic systems.
