Create NCT Layers
From the Model ribbon, click NCT Layers to display the Create NCT Layer Entity Editor.
Name
A character string used to label the NCT layer in subsequent SEAM applications. The name may be left blank, but the combination of the name and number must be unique. The name cannot contain the following characters: + - / * or ^.
ID
An alphanumeric string no longer than eight characters used to identify the NCT layer in subsequent SEAM forms. The NCT layer ID does not need to be unique, however, the combination of the name and the ID must be unique. To generate a unique numeric ID, click the "#" button.
A predefined type which describes the general form of the NCT layer type. From the Type field drop-down menu, select the NCT layer type.
There are four types of NCT Layers in SEAM:
  1. Decoupler
  2. Mass barrier
  3. Absorber
  4. Panel
Thickness
Assign a thickness to the layer.
Damping
Assign a damping model to the NCT layer. From the Damping field drop-down menu, select a damping model. This list contains all pre-defined models which apply to the current element type. Click to display advanced damping options that you can use to define additional damping models.
Properties
Assign a property model to the NCT layer. From the Property field drop-down menu, select a property model. The element materials and cross-sectional parameters defined in the selected property record are displayed. Property records can be used to simplify the model definition in cases where many elements have the same properties. Click to display advanced property options that you can use to define additional property models.
