Use the Macros tool to access pre-defined macros packaged with the NVH solution and
also user-defined macros.
From the NVH Tools ribbon, click the Macros tool.Figure 1.
Pre-defined macros are available in the Predefined tab.Figure 2.
User-defined macros can be added/removed in the Userdefined tab.
Add and delete options are available in the context menu. The
selected macro fetches the design variables from the model property database and exports
them to the FE input solver deck.
