2025
This manual presents solved verification models including NAFEMS problems.
View new features for OptiStruct 2025.
OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
Discover OptiStruct functionality with interactive tutorials.
This manual provides detailed information regarding the features, functionality, and simulation methods available in OptiStruct.
This manual provides a detailed list and usage information regarding input entries, output entries, and parameters available in OptiStruct.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides you with examples of the real-world applications and capabilities of OptiStruct.
This manual presents solved aerospace verification models including NAFEMS problems.
Rotor Bearing system is an excellent example of rotating machines used in mechanical engineering applications.
The Nelson-Mac Vaugh rotor model for rotor dynamics is described to determine the critical speeds at which resonance occurs. The Campbell diagram is used in to review resonance and stability.
This problem describes the Rigid Jeffcott model for rotor dynamics.
This section provides quick responses to typical and frequently asked questions regarding OptiStruct.
