PARAM, GLOBEXPT
Bulk Data Entry Applies to Global-Local Modeling. Expanding the interpolation patch results in a smoother solution near the cut surface.
| Parameter | Values | Description |
| GLOBEXPT | <0, 1> | If patch expansion is not
allowed, local stress hot spots near the cut surface may occur.
However, local model solution away from the cut surface will not be
visually affected.
- Disabling patch expansion is recommended when cut surface contains disconnected elements in near proximity (for example, two parallel thin structures).
