/ANIM/SHELL/FLDZ
Engine Keyword Generates animation files containing the FLD failure zone factor for the FLD failure model as function of a shell element integration point.
/ANIM/SHELL/FLDZ/Keyword4
Definition
Keyword4 Output location:
MEMB
Middle layer
UPPER
Upper layer
LOWER
Lower layer (number of integration points is equal to one)
  1. For a BATOZ shell element, the value is the average value of the Gauss points in the layer
  2. The values of FLD zone index are:
    FLDZ=6
    Failure
    εmajor>εlim
    FLDZ=5
    Marginal
    εlim>εmajor>εmarginal
    FLDZ=4
    Safe
    εmarginal>εmajor>|εminor|
    FLDZ=3
    Compression
    εminor>εmajor>εminorRani1+Rani
    FLDZ=2
    High wrinkle
    εminorRani1+Rani>εmajor
    FLDZ=1
    Loose metal
    εmajor2+εminor2>Factor_Loosemetal2
    Where,
    fct_ID
    Defined in /FAIL/FLD
    εlim
    Major strain as a limit from FLD diagram from fct_ID in /FAIL/FLD
    εminor and εmajor
    The minimum and maximum principal strains
    Rani
    Average anisotropy factor defined in FLD input in /FAIL/FLD
    Factor_Marginal
    Defined in FLD input in /FAIL/FLD
    Factor_Loosemetal
    α=arctan(Rani1+Rani)
    I_marg
    If I_marg= 2, the marginal curve is defined by shifting the FLD curve with the constant value Factor_Marginal
    εmarginal=εlimFactor_Marginal
    If I_marg= 3, the marginal curve is defined as a factor of the Factor_Marginal
    εmarginal=εlim(1Factor_Marginal)
